how good are they
Old May 23, 2011 | 09:48 PM
jimhc's Avatar
jimhc
big jc
Default how good are they
how good are the 205 block how much power and when would you need to upgrade to a 200block
Old May 23, 2011 | 10:36 PM
mechanic28's Avatar
mechanic28
its a lottery to be honest matey general rule around the 400bhp mark,but same die at 350 others can handle 500bhp
Old May 23, 2011 | 10:54 PM
jimhc's Avatar
jimhc
big jc
bloody hell thats a big diff fae 350 tae 500bhp. a wntn 450ish and was just wonderin if a could keep the 205 if it can handle it there was any point buyin a 200 thats all
Old May 24, 2011 | 12:02 AM
BRAMMER's Avatar
BRAMMER
My 205 block survived 441bhp as did the Grp A head gasket - i really wanted to continue on the 205 short motor as i only put 3k since a full rebuild but it's not worth risking any more with a GT turbo.
If you go for 450 then i would if your short motor is good
Old May 24, 2011 | 07:08 AM
There's many 500+ on 205 bottom ends, depends how well built it is and what parts are used, a "group a" HG will take 450 no bother, and has the added advantage of sealing better than any metal gasket with imperfect surfaces.
Old May 28, 2011 | 02:14 AM
dazzle740's Avatar
dazzle740
Mine's running approx 410-420bhp and I'm still on orginal 205 just rebuilt using quality parts. I know it not quite the 450 bhp your after but I don't exactly drive like miss daisy and I had no issues with reliability.
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
3doorcozmess
Sep 15, 2015 06:06 PM
markk
Sep 9, 2015 08:11 AM
cbminis
Sep 7, 2015 09:42 AM
turbowag
Sep 3, 2015 08:07 AM
