300bhp Cosworth Engine, £1k SOLD
Removed yesterday as im going for more power
205 block,
T3 turbo, no in and out play, Minimal up and down.
Green injectors,
4x4 Inlet
Will come with a chip and L6 ecu for this car, Mapped by Enhanced performance and been checked over on the dyno recently.
Will throw in a used AP 6 paddle clutch, there is a little life left in it.
Fancy HT leads
Could probably do with a set of valve stem oils seals and possibly guides, did get a bit of smoke on the overun occasionally.
Edit : I think i have found the cause of the smoking issue, when i first fitted my breather i had no smoke at all, then it came back after about 1k miles. when i took the breather system apart to fit it to my new engine i found the pipe off the kidney box was pretty much collapsed inside
will be missing a few odds and ends, some sensors, throttle body, alternator, ps pump and crank pulley.
can also include a quite tired wiring loom, spare iscv etc.
Not sure what its worth really, £1500? make us an offer. reduced to £1000 now as im fed up of falling over it.
can deliver so long as its not a million miles away and you pay for my fuel.
i'm useless at checking back to the thread so PM me.
Edited with more pictures and info:
What you see here is what you get, apart from HT leads which i will have to dig out. The head is missing 3 exhaust manifold studs, and the manifold has a slight crack, it didnt leak when in the car so you might get away with it, you might not.
The ecu has also had 2 extra earths soldered on to the back of the pins as my old wiring loom was dead. should be fine though with a decent loom, or fit the chip into another L6
Amal valve cover and bracket, £15+post?
205 block,
Green injectors,
4x4 Inlet
Fancy HT leads
Few more bits and ive edited the above post about the smoking problem.
Open to offers on all items.
K&N Air filter and roose motorsport hose to suit T3
£20+post, will give the filter a good clean and oil before sending.
Standard coil, still has a bit of loom attatched, with chrome sleve, will polish up nice.
£15+post
Roose Motorsport T3 to 63mm intercooler (standard size i believe) good condition, no splits etc. this is the high temp double thickness one.
SOLD
Good condition standard 2wd engine mounts, £25 +post
Small turbo escort 70mm throttle body, ISCV and TPS, all working perfectly.
£offers
£15+post
SOLD
£offers
The ISCV on the throttle body is different to what will be on yours Scotty mate.... besides, I want that TB complete with ISCV and TPS
Yours will be one of these ones....
big_Rad
Sep 15, 2017 09:36 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
