ST170 Turbo Build
Old May 21, 2011 | 07:34 PM
setco's Avatar
setco
Default ST170 Turbo Build
Hello everyone,
I think its time to start my thread in regard to the turbo build I'm doing. The car was a 1.6 to start. Decided to do a swap for an ST engine (got a donor) and put in a turbo (gt28rs). I'm keeping the factory ECU (1.6) to control the AC and keep factory interior wiring loom. I want to put in a second ECU from DTAfast to be in charge of the engine and performance part. I think that it should work.
I'm looking at around 350bhp as a final mark. I have some doubts however
What type of fans and intercooler size should be used? Right now the intercooler I have fitted is too big requires to cut up the collection front and I don't want to do this. The fans are too close to the exhaust also.
What inlet manifold would be best?
Before the work started
Current work stage
Old May 23, 2011 | 12:21 PM
Sp3no's Avatar
Sp3no
What is wrong with the inlet manifold you have on there? For 350bhp a rover turbo manifold will be fine with adaptor plate. What Exhaust manifold you using? I would go for a standard Focus RS item and this should clear your fans
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Rsmat
42
Sep 1, 2015 09:39 PM
mrknifey
Aug 30, 2015 11:48 AM
muz
Aug 16, 2015 12:57 PM
