Oil flow
Old May 21, 2011 | 11:02 AM
Brettski mk2's Avatar
Brettski mk2
Default Oil flow
Hi dose the oil flow from the middle of the filter housing and back in round the out side or the other way round
fitting the remote oil filter housing and cooler
Old May 21, 2011 | 05:37 PM
Other way around, where the filter goes on the block you will see a hole at the bottom of the area inside the "ring" the filter seals on, this is DIRECTLY from the oil pump, so it flows through the outer holes into/through the filter and out the single one in the centre into the oil gallery, and onto crank/pistons etc etc.
Old May 21, 2011 | 06:05 PM
Brettski mk2
Cheers Tab
Old May 21, 2011 | 08:26 PM
No worries matey, this seems to baffle a few people, used to baffle me as well!!
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
