starter motor help!!!!!!!!
Old May 20, 2011 | 03:59 PM
mgbrs's Avatar
mgbrs
Question starter motor help!!!!!!!!
right starter motor is fooked on my work hack, its a 2.0ltr ghia auto on a G plate, i,ve removed the old one, and when i rang the scrappers, they asked is it cvh or pinto, so i presumed it was the pinto type, anyways got it home and its not the same size, but surely its not the cvh type?? someone help!! and i know i should of took the old one down
also is the cvh type starter motor for the DOHC engine which mine is??
need get it sorted this weekend!!!!
cheers in advance
Old May 20, 2011 | 07:01 PM
On a G reg, it's almost defo a pinto, the CVH didn't come in 2L size so it's not that.
How wide is the rocker cover on your sierra, is it flat about 10" to a foot wide, if so it's DOHC, the pinto cover is much narrower about 6-7" and rounded/ish over the top.
Did you tell them it was a AUTOMATIC ?, as the starters are normally specific to auto or manual, certainly on the pinto a manual starter will not work on a auto, the nose of the starter is a different depth, due to the teeth on the flex plate of the auto being a lot closer to the engine than the flywheel teeth of the manual box.
Old May 21, 2011 | 01:20 PM
mgbrs's Avatar
mgbrs
cheers for the info no i didn't mention that it was a auto, when i have put the two together, the pinto one is larger than the one i have removed from the car. the car is defo a DOHC. so what iam i asking for a... "pinto auto starter motor for a G plate saph"?? really appreciate the help cheers again
Old May 21, 2011 | 05:32 PM
You need a AUTO starter for a DOHC, forget pinto, it doesn't come into it, I've had many ford auto's over the years and always found the starters were different.
What is actually wrong with your starter anyway ?, they are dead simple to fix, normally only needing brushes, I've even cut down washing machine carbon brushes before and used these in starters, it's easy to over haul one.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
