cheapest place to buy standard piston rings for s2 rst?
Old May 19, 2011 | 06:32 PM
Joe91's Avatar
Joe91
Default cheapest place to buy standard piston rings for s2 rst?
As per title anyone?
Also how much roughly is it to have your pistons skimmed 1mm?
Thanks, Joe.
Old May 19, 2011 | 07:24 PM
russ rs's Avatar
russ rs
try matt lewis motorsport
Old May 20, 2011 | 04:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I bought mine from ebay but make sure they are genuine Mahle.
Skim is around Ł40 from my local engineers, why do they need skimming mate?
Old May 21, 2011 | 08:28 AM
Joe91's Avatar
Joe91
Ok mate, can you point me in the right direction i.e ebay link or something, i know ill buy the wrong ones thats all!
And im getting the skimmed so i can run more boost without it blowing up again!!
Old May 21, 2011 | 11:05 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Just look for Mahle RST rings mate..
Unelss you want well over 300bhp you do not need to skim your pistons.
Old May 21, 2011 | 04:05 PM
Rob_DOHC's Avatar
Rob_DOHC
As above, seems to be a trend at the moment lol
I bought these, and im happy with them http://www.burtonpower.com/parts-by-...33716-std.html
Not the cheapest, but according to a few engine builders i spoke to meant to be some of the best.
Rob,
Old May 21, 2011 | 07:18 PM
tejy's Avatar
tejy
ive got a set of piston rings mate if your interested, was going to use them for mine but found out after getting my pistons back from getting cleaned up that they are 0.5mm oversized, so ive got standard spare set. pm me if your interested
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
adam151082
Aug 11, 2015 04:50 PM
Adam-M
22
Aug 10, 2015 10:46 AM
dlwarrior
Aug 5, 2015 10:19 AM
