possible fuel problem again
Old May 17, 2011 | 05:48 PM
jimhc's Avatar
jimhc
big jc
Default possible fuel problem again
on tick over the revs pop from 900 to 1500rpm with strong smell of petrol and small amount of smoke. if you keep revs at 1000rpm it slightly splutters higher revs it clears and drives fine any help would be great! thanks
Old May 17, 2011 | 06:39 PM
Could be a dicky plug, or a leaky injector.
Old May 17, 2011 | 06:47 PM
jimhc's Avatar
jimhc
big jc
Default problem
and how would i check them for problems?
Old May 18, 2011 | 08:08 AM
Try a new set of plugs, around £10 for some 071, try getting the injectors cleaned, sounds more like a injector, but lots of other things it could be, have you checked the fuel pressure/pump voltage, when was the filter last changed etc etc.
Old May 18, 2011 | 10:32 AM
jimhc's Avatar
jimhc
big jc
plugs were changed last month using pfr7b ngk. Filter unsure
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
