saff fuel hoses?
I just bought a new bosch fuel pump 941 and filter for my 92 j saff 4x4 but I dont have the old hoses and finishers etc still available. Can anyone tell me what hoses,finishers etc I need for the pump and filter etc...I thought it was 8mm ID but I'm not sure. Would be fitting new braided hoses etc so if anyone knows what I need and maybe best place to buy these parts I would be very chuffed with your help...cheeRS.
The main hose run from rear to front is 7.92mm, 8mm in practice, it's up to you what type of hose you use, I would advise against steel braided, as this stops you being able to inspect the hose itself due to the braid for the tank to pump pipe, which I think is 16mm id.
I bought all my new new hoses and fittings from a company called Pirtek. Take the pump/filter down and they'll find the hoses to match. Also a choice of hoses ie braided, rubber, silicon etc
cheeRS
cheeRS
Thnx for the advice tabetha and cossiedad much appreciated. Parts are on there way which I got from pirtek and matt lewis racing. So if the weather stays good this weekend I hope to get the saff up and running again..cheeRS again!!!
Thnx again cossiedad and tabetha..
Hope to get it running at least, the poor things been sat idle for nearly three years and I did'nt have the heart to sell or break it so I'm going for a labour of love and try and get her roaded again.It will take a while to get her in good shape again but i think it will be worth it.Not sure how my wallets gonna cope with it..hehe. Keep u posted on how i get on..cheeRS and oh yeah tabetha i heard some real spooky happenings going on in those undercity tunnels in Edinburger but nothing a good dram won't cure!
JK12
33
Apr 26, 2021 12:09 PM
timsrs
22
Sep 24, 2015 08:14 PM
