G Reddy Profec B Boost Controller Brand New
Old May 14, 2011 | 12:21 PM
rsturbo91's Avatar
rsturbo91
Default G Reddy Profec B Boost Controller Brand New
Black G Reddy Profec B Boost Controller
Brand new
Comes with full Fitting instructions
£150 delivered
The GReddy PRofec B-spec. is one of the simplest, easy to use electronic boost controllers on the market today. Available in either Black or Clear Blue cases, the PRofec B-spec uses a reliable twin-solenoid valve control motor. There are two presets labeled Lo. and Hi., as well as a Balance knob to alter the wastegate boost response. This unit also can be used with both integral/actuator or external/poppet style wastegates good for twin and sequential turbo setups.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
AJC
Oct 8, 2015 11:09 AM
