G Reddy Profec B Boost Controller Brand new
Old May 14, 2011 | 12:20 PM
rsturbo91's Avatar
rsturbo91
Default G Reddy Profec B Boost Controller Brand new
Black G Reddy Profec B Boost Controller
This was fitted into my escort but never wired up or used
Can leave it fitted to the panel (pic below) so can be put straight into another escort if you want
Comes with full Fitting instructions
£150 delivered
The GReddy PRofec B-spec. is one of the simplest, easy to use electronic boost controllers on the market today. Available in either Black or Clear Blue cases, the PRofec B-spec uses a reliable twin-solenoid valve control motor. There are two presets labeled Lo. and Hi., as well as a Balance knob to alter the wastegate boost response. This unit also can be used with both integral/actuator or external/poppet style wastegates good for twin and sequential turbo setups.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
AJC
Oct 8, 2015 11:09 AM
