RS Turbo metering unit, corbeau bucket seats and mint rst dizzy and mfi head!!!!
Hi there,
Im having a clear out.
This is a metering unit from my 88 rst, the car had covered just 64000 miles (hence condition), and had been setup at torque of the devil around a month before i removed it from the car to complete an EFI conversion.
I shouldn't think there are too many in good condition any more! A set of new banjo's and a good clean and im sure it could go on a concourse (think thats how you spell it!) car...
Its been stored in my wardrobe, and im tired of my clothes spelling like petrol lol
The photos show the unit as removed from car so a little grubby, but im sure it would clean up great!
It comes with every thing you see, the car was setup with new sensors etc so i suggest you do the same, it ran 17.5psi of boost and went really well. Started first time every time, hot and cold and drove really well.
This is the dyno graph, the car had a standard head, cam, bottom end etc, and i think a stage2 turbo (could have been a standard turbo too!).
Price is £100, you can pick it up or add a tenner for postage.
I've got a few other bits off the same car for sale too (mint distributor, and original head).
Rob,
Rob,
This dizzy is in great condition, worked perfectly. Comes with every thing in the pictures, the cap and rotor arm were fitted a few hundred miles before i removed it and were decent parts from MSD.
Price is £40
Rob,
Price is £40
Rob,
MFI head, original and untouched, i don't even think its ever had a skim!
It cam off a car running fairly low power, the car never overheated etc. It comes with all the valves which look good, and standard ford springs which are good to use with nearly all cams (original or after market).
Needs a good clean, but all looks good.
Price is £40 and its probably a pick up job.
Cheers,
Cheers,
These are some bucket seats that came with the car,
You can still buy them from here for some £205 each with out sub frames
http://www.hyeline.com/corbeau.htm
The drivers side has a hole in the bolster, it looks like an easy repair, i was going to use a leather self adhesive patch, but on reflection i'll leave it to the buyer in case my repair isn't up to scratch!
They were very comfortable, and if my car wasn't having a standard interior i wouldn't sell them.
They come with the subframes and bolt straight into an rst, but would obviously fit most other cars with minor changes.
Price is £120,
Rob,
Price is £120,
Rob,
Thanks to which ever mod fucked my for sale threads. Now they make literally no sense.
If your going to move some ones posts, at least let them know so they can edit them.
The metering unit, dizzy and head are on ebay at the moment
Metering unit
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Dizzy
Head
Rob,
Metering unit
Dizzy
Head
Rob,
