Few engine parts, Knife edged crank, steel rods etc
Ok folks have checked the rules and it says nothing about making people aware of ebay ads.
These are my parts so not advertised for someone else etc.
Knife edged crank
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Ported head (spares or repair)
Steel rods of unknown brand
BD14 Exhaust cam
2wd Water pump
Rocker cover
Any questions feel free to ask other than buy it now as they will all be left to run.
Ta
Gavin
Knife edged crank
BD14 Exhaust cam
2wd Water pump
Rocker cover
Ta
Gavin
Hi gav, long time now speak, will the head just need new caps? or has it scored the side that's attached to the head (sorry hard to describe)
also interested in the crank also ;o)
just bid your head up past £50
. to be honest, thats a bloody easy repair for me, infact if it was my own car, i'd just rub it with some emery and call it done as i've seen ALOT worse on running cars
. alternatively to do it properly, you'd just line bore it, which means taking a bit of metal off the top of the head and the caps and re-machining to the right size
Sorry bud as said not finishing anything early
Hi Pete, has been a while bud.
There is a little scoring to the other side but the caps and the actual cam are worst.
Thanks Jim
I did a search after the first post to see what clasifies a Knife edged crank and all the information I found said the leading edges of the counter balance were machined to a point mimicking that of a knifes edge (hence the name)
Maybe mine has not been done to the full extent possible I do not know and can only go off the information I am told or read.
If I am wrong I will amend but anyone that is interested can see the pictures and make there own mind up if they think its worth bidding or not.
Cheers bud,
To be honest I was told by a few mates to just list as a good head but im not that sort of person.
If its as described there can be no come backs and im covered even though it means its worth less better to be truthful, but thats just me.
.To be honest I was told by a few mates to just list as a good head but im not that sort of person.
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Zoggon
Aug 10, 2015 10:39 AM
lockie
Jul 31, 2015 10:03 PM
