ive just brought another mk4 turbo only difference is thats tis one is a 1.8 zvh i know some of the spec but after having a litte nose under the bonnet i notice theres no oil cooler is one needed and is there and other musts for these zvh setups
do you mean the oil cooler that comes standard down the back of the block on rs's?? or dont you mean an aftermarket cooler? its not realy needed im running around 300hp with out one
yeah thats it a standard s2 comes with an oil cooler fitted in front of the oil filter so was wondering if id need any sort of oil cooler for the zvh,
is there any must does on the zvh
