Tacho not reading correctly
Old May 11, 2011 | 05:13 AM
TCR's Avatar
TCR
Default Tacho not reading correctly
Hey guys,
I have a small issue with the tacho in my Sierra RS Cossie. The tacho is working but not reading correctly. At crusing speeds it reads about 1000rpm and when I run through the gears to what I think is about 5000rpm, it only reads about 2500rpm.
Before I go taking it apart, any idea on what might be causing this?
Old May 11, 2011 | 01:10 PM
martysmartie's Avatar
martysmartie
First off have you changed anything (Adding wasted spark etc?) If no I should think it's a bad connection or track on the PCB.
Martin
Old May 11, 2011 | 01:26 PM
As said if not changed over to WS, that's just how they go I'm afraid, they can be repaired and even reworked inside, tap the tacho and see if it jumps when stuck, occasionally the centre of the dial face lifts and physically stops the needle from moving freely.
Old May 11, 2011 | 10:20 PM
TCR's Avatar
TCR
I've only had the car a couple of weeks but as far as I can tell it's a stock car except for a stage 1 chip and mongoose exhaust. The needle still seems to move freely enough, it's just that it doesn't read correctly. Thinking it's bad connection or an electrical issue of some sort causing the faulty reading.
Old May 12, 2011 | 08:58 AM
They're very simple instruments, but do go wrong, esp with age, you could always try running a different earth direct from the battery to the rear of the rev counter, if that fails add a new live direct from coil negative, this would remove old wiring's high resistance, post up results if you do, would be interesting for others.
Old May 12, 2011 | 10:57 AM
TCR's Avatar
TCR
Thanks, I'll keep you posted
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
