fiesta turbo and zvh wat injectors
you would need high impeadance lancia injectors which flow just a little more than bieges.
No point really as the batch firing system wont control them that well, and only running 1 bar of boost wont use them to their full potential anyway.
Be much better off with a sequential management system, decent injectors and a nice amount of boost. 1.5+bar at least if you have a good built engine with rods and pistons in a ZVH. Should see 300bhp with 4x4 turbo. Getting that mapped up will cost half as much as it would trying to do the same on FRST EFi. Seems a no win situation to me.
Loads of costs and still no power..
do you reckon im pissing in the wind with my expectations jano?
ive got
forged pistons
mictropolished crank
farndon rods
custom inlet
stage 3 t3 from cr t's
sitech zvh ported head
etc
can you give me an educated guess on what to expect from 18psi from what you have seen in the past.
p.s. had a customer equiery the other day recomended from yourself, much appreciated!
ive got
forged pistons
farndon rods
custom inlet
etc
The turbo is the main part that will either give you good power or limit it.
Stages dont mean anything to me. There is no-one who determins what stage 1 is compared to stage 5 etc. Idealy you want a 4x4 comp wheel and housing with a .48.
running 18psi with oversize valves on a cvh would make 230bhp.
Next is that 803's wont run 300bhp on an 8v and top out at about 270bhp obviously depending on how good or bad the head is.
Ive seen lots of dash's done by you now, so have no worrys sending custom your way as i know it will be a good job done.
Im building (nearly finished) a 2.1 zvh. Im running 346cc injectors. Not sure what im going to get tho or wat to expect????
Spec:
2.1zvh
T3 (stg3) but prob changing this to a t34
346cc injecctors
Crazycage zorst manifold
DTA ecu
Massive intercooler.
What power should i expect?
( sorry to hijack, might help you deside injectors)
Spec:
2.1zvh
346cc injecctors
DTA ecu
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
