'Clunking' Noise When Braking - Help!!
Old May 10, 2011 | 02:19 PM
Cozziekid's Avatar
Cozziekid
Default 'Clunking' Noise When Braking - Help!!
Had a problem with my brakes for a while and its baffled me a bit, not to mention the local garage!
Ok bear with me lol... 8 times out of 10 when i brake from 30mph + i get a rhythmic clunking noise consistent with the speed of the car coming from the front.
The noise slows down as the car slows down, carries on until the car stops and i can feel a clunk through the brake pedal consistent with the clunking noise.
I dont have to brake hard for the noise to happen, so it doesnt seem to be the ABS kicking in too early to me, correct me if im wrong lol.
Sometimes if im at motorway speeds i can feel the pedal go down slightly further just before the noise starts.
Also the ABS and TC lights come on when i reach 60mph + and the TC light will flash when cornering normally and i can feel the power being cut down as a result.
No fault codes flag up and i have changed front discs and pads together with front ABS sensors, all to no avail!
Im thinking of changing the ABS pump anyway just to rule it out even though i was told it was fine.
The local garage have got no idea whats wrong, its cost me a fortune so far and its starting to drive me insane
Any help gratefully received, thanks. <--- real tears lol.
Old May 11, 2011 | 07:43 AM
RichieST's Avatar
RichieST
I would try pulling the fuse for the ABS temporarily to deactivate it, to see if it is your problem!
Old May 11, 2011 | 11:48 AM
Cozziekid's Avatar
Cozziekid
Good point, i'll try that today cheers
Old May 11, 2011 | 01:11 PM
Phil2002's Avatar
Phil2002
http://www.bba-reman.com/content.asp..._and_tips#ford
Have a look one here mate some times can be really useful.
good luck,
Phil
Old May 13, 2011 | 08:42 PM
Cozziekid's Avatar
Cozziekid
Thanks for the link phil, some good stuff on there.
Ok, so i finally got around to pulling the ABS fuse today (No.30 in the fuse box behind glove box), took it for a spin and.......... no clunking noise
I guess the ABS pump might be fooked then. Could it be anything else like a pressure sensor etc?
Old May 13, 2011 | 10:07 PM
RichieST's Avatar
RichieST
You could try cleaning up the toothed rings that the ABS sensor picks up from. At least you know it is definately an ABS fault rather than anything else! If it were mine I'd be tempted to leave the fuse out and whip the bulb out!
Old May 14, 2011 | 12:37 AM
Cozziekid's Avatar
Cozziekid
I would do rich, but aren't the abs and aibag lights becoming part of the mot soon? Im sure i heard it mentioned somewhere. Think i'll have a mess with it over the weekend, clean a few things and see what happens. Certainly feels like the clunking/vibration is coming from passenger side front wheel so i'll check the abs rings etc.
gingeRS
17
Oct 2, 2015 09:42 AM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
