Best flowing dump valve
My "forge copy" bov does not flow properly, i can still hear the turbo stalls a little bit even with low boost.
Does anyone have any suggestions to a better flowing one? Preferably a recirculating one. Unfortunately i only have a 25mm outlet in my boost hose.
Turbocharging Technician
The raeson behind this is becuase the boost pressure has to overcome the tension on the secondary piston spring, or the main spring is slightly too strong, fitting a single piston dumpvalve or one with an adjustable main spring rate will cure this, but i dont think its a flow rate problem if you hear it light throttle/ low boost.
this one flows really well,
makes almost no noise at all because it flows so well!
http://shop.motorsport-developments....-bov-688-p.asp
its fookin massive!
its fookin massive!
PassionFords Creator
