rear discs conversion, bled 3 times and still spongey?????
Old May 8, 2011 | 09:20 PM
wedge07's Avatar
wedge07
Default rear discs conversion, bled 3 times and still spongey?????
hi done a rear disc conversion on my escort mk4 and bled them 3 times, when i push my foot on the brake there really spongy? i cant get my car through an mot until i sort this! anybody got any ideas please help me??????
Old May 8, 2011 | 09:35 PM
steves24V's's Avatar
steves24V's
If the convertion means the calipers dont seat on the car at the same angle as they did on the car there are off they may still be air in them.
You need to make sure the bleed nipple is at the highest point when bleeding them, may have to unbolt them from there mounts just to bleed them and put them back on to test the pedel (I had the same prob on a kit car a while ago took me a while to figure it out.)
Old May 8, 2011 | 09:43 PM
wedge07's Avatar
wedge07
So u dont think ill be needing comoensators or anything like that?
Old May 8, 2011 | 09:50 PM
steves24V's
couldn't say it was just something simple you should check as it had me stumped for a while and turned out to be really simple.
Old May 8, 2011 | 10:06 PM
155lee's Avatar
155lee
undo the caliper bolts and hold the piston vertical as the rst brackets dont make the bleed point the highest point of the caliper,therefore trapping air.if the problem persists its time to ditch the abs,i had to do both to mine when i fitted discs before the spongeyness went away.
Old May 8, 2011 | 10:53 PM
wedge07's Avatar
wedge07
ok ill have a go of that tomoz wen I finish work if it aint leatherin it down nice one for that guys, appreciate it
Old May 10, 2011 | 10:05 AM
wedge07's Avatar
wedge07
Ok done all that and they spot on now, cheers car can go in for mot now cheers
Old May 10, 2011 | 11:19 AM
alxf's Avatar
alxf
See when you fitted the rear discs and calipers, do you have the hand brake cable at the top or bottom of the caliper?
Old May 24, 2011 | 11:01 PM
wedge07's Avatar
wedge07
mine are at the top mate hope that helps
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
