fuel pressure actuator
Old May 8, 2011 | 03:16 PM
foreverford255's Avatar
foreverford255
Default fuel pressure actuator
hi all
first ill start by apologising for the long post lol
i took my s2 in for a set up at a local firm and it appears that it wasnt raising fuel pressure with the boost so further investigation revealed a dodgy connection to the fuel pressure actuator.
when that was fixed it was then massivley overfueling so he removed the fuel pressure actuator and it had been wound all the way in, so my tuner recons that they cant be wound back out once theve been wound in, so he said i have to replace this then go back which has left my car very poorly as it keeps cutting out after about 1 and half miles and i have to switch it off then crank it over and eventually it will start and drive ok again.
so my question is ,,,is it true that the fuel pressure actuator isnt adjustable
i have tryed another actuator on it but it ran even worse coughing and spluttering
just wondering if its worth putting another metering unit on from a standard car
any info would very much appreciated
thanks
mick
Old May 8, 2011 | 04:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats rubbish mate, you can adjust them in either direction, all he had to do was turn it anticlockwise until the on boost AFR was correct... Job done!
Old May 8, 2011 | 06:10 PM
project rs's Avatar
project rs
any chance of a pic just so we are deffo talking same object as i think you are on about regulator not actuator
Old May 8, 2011 | 07:50 PM
foreverford255
it bolts onto the side of the fuel distributor on the metering unit
karlos thats what i thought coz it would be a bit daft if it could only go one way
im a bit unsure what to do now as i cant even drive the thing i might get another metering unit
Old May 8, 2011 | 09:12 PM
stevealien's Avatar
stevealien
10 Year Member
plus 1 mick
did he even attempt to back the fuel pressure off abit??????
Old May 9, 2011 | 05:50 AM
foreverford255
he said he did mate but im unsure if he did
Old Sep 29, 2014 | 06:42 PM
Nicol.'s Avatar
Nicol.
Anyone know what voltage the regulator should get. I'm only getting 8 volts to it but thought it would be 12? I'm not getting any fuel to the cylinders from the distributor wasn't sure if this could cause that?
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Dubs44
Sep 19, 2015 06:31 AM
