cortina gearbox problems...
May 7, 2011 | 12:56 PM
Hi
i am having problems with a cortina where i cannot find reverse gear and wondering if i may be missing a trick?
its a 4 speed manual gearbox attached to a 1.6 pinto engine, all the forward gears select no problems but i cannot seem to find reverse?
Any help
Steve
May 7, 2011 | 05:27 PM
Try it with the engine off, is it any better ?, you may have clutch drag, or a bent/damaged selector fork for example.
May 7, 2011 | 08:13 PM
Quote:
Originally Posted by
i was trying it with the engine off will see when its running
May 8, 2011 | 12:00 AM
have you taken the gearstick out and put it back in the wrong way round?
i personally havnt had the gearstick out as ive just bought the car, all the other gears work ok
May 8, 2011 | 12:20 AM
unscrew it and check it's in the right way, there's a grove one one side that fits round a block in the selector housing when you push the stick down, easy to put it in the wrong way
May 11, 2011 | 05:58 PM
found reverse, i had to move the stick across to near 1st then push down firmly and across again
cheers
Steve
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
