s2 arb bracket
Old May 6, 2011 | 11:23 PM
teahan's Avatar
teahan
Default s2 arb bracket
are the brackets that hold the bush still available from ford? the u shaped one.
Old May 6, 2011 | 11:36 PM
Rob_DOHC's Avatar
Rob_DOHC
ebay mate or YWK parts, around £12 for the pair.
Rob,
Old May 6, 2011 | 11:43 PM
teahan's Avatar
teahan
Rob,
i thought i saw them before on ebay, just gave about 3 hours looking for them, no luck! i'll try again!
Old May 7, 2011 | 09:07 PM
Rob_DOHC's Avatar
Rob_DOHC
These bits here (zinc plated parts)
Rob,
Old May 7, 2011 | 09:52 PM
Rick's Avatar
Rick
Rob, are you actually going to drive that or just stare at it
Old May 7, 2011 | 09:58 PM
Rob_DOHC's Avatar
Rob_DOHC
Lol, drive it and do it all again in a few years i assume!
Old May 7, 2011 | 10:05 PM
Rick's Avatar
Rick
are you going to spank it on track/pod etc? Mine is getting closer to being on the road and it's getting the shit kicked out of it as much as possible
Old May 7, 2011 | 10:11 PM
Rob_DOHC's Avatar
Rob_DOHC
Im undecided about track tbh, i think if i ever get into track stuff my daily 328 hack would be better round a track than an rst, or maybe an old m3.... but pod definitely, and i drive cars pretty hard anyway tbh.... I just couldn't face totalling it on track.
Just avoid salt like the plague, and really shitty days + clean it regularly etc and it should hold up okay (i hope).
You can build one and not give it a good spanking in my book Have you got a build thread or anything for yours Rick? Always fancied a nosey!
Rob,
Old May 7, 2011 | 10:38 PM
Rick's Avatar
Rick
no build thread. After 12 years it would get a bit tedious! Was a daily driver from '99 to 08 when it was running a 300hp CVH. Dropped a valve, so decided to put a 2.3 I4 RSK engine in. Then a very cheap ST170 came up locally so used that instead. Had it running with a FRS box, and power steering last year for a bit but Gary decided he didn't like the engine mounts so ripped it all apart.
Since then i've got a replica/fibreglass S1 kit for it so I can run as wide a wheel as possible. Cut the arches out big style so just throwing on some paint. All the sanding/prep bores me but it'll be done soon enough.
Rick
Old May 7, 2011 | 10:49 PM
Rob_DOHC's Avatar
Rob_DOHC
Good stuff Rick, I look forward to seeing it one day! You sticking with the st170 lump for the time being?
Rob,
Old May 7, 2011 | 11:12 PM
Rick's Avatar
Rick
its fully steel, but yea. People have had problems with the heads flexing, if that happens then i'll put a black top head on it. I know for a fact they can take a kicking!
Old May 8, 2011 | 01:57 PM
neil73's Avatar
neil73
I might have a pair knocking about, I'll have a look and let you know later
Old May 8, 2011 | 09:21 PM
teahan's Avatar
teahan
just bought a set from wyk parts, said i'd go new, thanks rob
Old May 8, 2011 | 11:05 PM
Rob_DOHC's Avatar
Rob_DOHC
No worries mate, best of luck!
Haha good stuff, be good to see it at the pod some time then!
Rob,
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
truffleshuffle
Sep 10, 2015 09:35 PM
