Loosing coolant from the thermostat housing
Old May 5, 2011 | 01:20 PM
wrighty74's Avatar
wrighty74
Default Loosing coolant from the thermostat housing
Car is doing my head atm,stat housing is leaking now(st170)
Best price to get one from?And is there anything else i need to get replaced while im there (ie gaskets etc)
Spent a small fortune on it recently cambelt kit replaced,full service,wheel bearing and now this happens
Bloody cars
Old May 5, 2011 | 01:35 PM
RichieST's Avatar
RichieST
It'll be the seal on the bung in the underneath of the housing, very commonly fail on the st170s. Just search for it on google and you'll find lots of info on it.
The replacement plug and seal is available from Ford, no doubt they will try and sell you the complete housing but don't be fobbed off!
Old May 5, 2011 | 04:42 PM
wrighty74's Avatar
wrighty74
Thumbs up
Cheers fella,will go down to fords and see if they can supply me the plug@seal
Old May 5, 2011 | 09:29 PM
LewisT's Avatar
LewisT
i would remove the three bolts on it and pop it to the side, they have a nasty habit of cracking around the seal on the inner plastic lip that holds the seal in place, would check that aswell before buying the bung
Old May 6, 2011 | 01:03 PM
CarParts Express's Avatar
CarParts Express
yep as said above check the lip where the seal sits in as they break away in there
fordrallycar
Sep 30, 2015 07:57 PM
The Enigma
Sep 29, 2015 10:31 AM
