bosch 044 non return valve is it needed.
May 5, 2011 | 01:03 AM
bosch 044 non return valve is it needed. cause im wanting to fit aeroquip fitting to the pump and i cant see any other way of doing it unless i remove the valve.
May 5, 2011 | 07:20 AM
No not essential, so long as you have a decent prime period, of 3-4 seconds the rail will fill to pressure, so not a problem to delete it.
May 5, 2011 | 07:40 AM
anyone got a non return valve they would sell?
May 5, 2011 | 02:02 PM
Quote:
Originally Posted by
B13 JUS
I think i have 2 of them , brand new .
May 5, 2011 | 02:40 PM
fit the nrv, I didn't have one in my sierra when I first got it, took and age to start from cold till the fuel got to the injectors.
steve
May 5, 2011 | 02:48 PM
is there any other way of fitting aeroquip with the non return valve on. i now i can use a banjo version of aeroquip but i dont really want to use a banjo.
many thanks to all of your replies
May 5, 2011 | 06:06 PM
B13 JUS
I have a box of them somewhere, not from the 941/044 but same valve.
May 5, 2011 | 06:08 PM
So long as the car starts ok, ie is a first time starter it won't be a problem without, done many other cars without.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
044 ,
2003 ,
bosch ,
deadheading ,
fitting ,
focus ,
ford ,
needed ,
nonreturn ,
o44 ,
pump ,
return ,
valve
