Brake bias valve
Old May 4, 2011 | 08:34 PM
rudkinrst's Avatar
rudkinrst
Default Brake bias valve
Hi. I have just bought another series 2 and got told the rear brakes need bleeding. We have passenger side done fine but the drivers side will not bleed. We have un seized the brake bias valve and yet it still will not do anything. When you put your foot on the brake the drum still moves. Was wondering if anyone had any advice. Need to get it sorted then it's for a few hours on the dyno.
Thanks
Old May 4, 2011 | 10:02 PM
Rob_DOHC's Avatar
Rob_DOHC
Maybe a seized slave cylinder, have you taken the drum off yet to see.
Rob,
Old May 4, 2011 | 10:18 PM
rudkinrst's Avatar
rudkinrst
Yes Mate seems to work ok. If you put a pry bar on the bias valve you can get the wheel to nearly lock just can't get it to work properly
Old May 5, 2011 | 10:54 AM
rudkinrst's Avatar
rudkinrst
ive just bought a new slave cylinder and will fit it saturday, was also wondering if there was a way to bypass/ remove the load valves on the rear axle.
Old May 5, 2011 | 11:06 AM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Is the car "under load" when you bleed the rears as if not the bias valve could be shut when you bleed - if you bleed with the car jacked in the air the valve shuts fully and will not bleed.
Old May 5, 2011 | 11:37 AM
Rob_DOHC's Avatar
Rob_DOHC
As above, put a jack under the swing arm you are bleeding.
You can by pass them, but really to do a proper job you will need to do a lot more than just that.
Rob,
Old May 5, 2011 | 01:07 PM
rudkinrst's Avatar
rudkinrst
yeah we had the car on axle stands under the rear wish bones wen we bled it. with the car down on the ground tho it sat alot lower than on stands.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
wattie
Sep 16, 2015 11:34 PM
cossirob
Sep 3, 2015 09:17 PM
