EFi Fuel Pressure
Old May 3, 2011 | 10:16 AM
Rogeyboy's Avatar
Rogeyboy
Default EFi Fuel Pressure
Just brought and installed a fuel pressure gauge in my car, the car drove nicely but would get warm abit quick if worked harm and would hesistate at around 70mph on a cruise before the gauge was fitted...
Fuel pressure should be at 3bar, i had 2.6bar with an uprated pump and regulator! Ive now adjusted it to 3bar and the car drives superbly, doesnt get hot once worked and doesnt hesistate at all!
I'd highly recommend one of these gauges to anybody!
Old May 3, 2011 | 09:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Glad your sorted Rog! Was obviously a bit lean, luck you caught it before any damage occurred!
Old May 4, 2011 | 09:11 AM
Rob_DOHC's Avatar
Rob_DOHC
Well done mate, good investment. Where did you fit it? under bonnet?
Rob,
Old May 4, 2011 | 10:25 AM
Rogeyboy's Avatar
Rogeyboy
Cheers Karlos - It was your advice that made me go and get a gauge!
Its fitted inline after the fuel filter in the fuel feed hose under the bonnet... Mental Note: Get a new fuel filter on there too!
Any1 going to southend 2nite for the PF meet?
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dubs44
Sep 19, 2015 06:31 AM
