Tuned zetec and stage 2 cts box/obx manifold/silicone hoses
Im thinking of selling my tuned N/A zetec as i dont have time to complete the car it was supposed to be going in at the moment.
Spec is
2l silvertop bottom end with 1.8 head for slightly raised compression. Has had new water pump and timing belt about 3k ago. St170 headgasket when head was fitted about 1k ago. Its a stage 3 ported and polished silvertop heads with bigger valves, supplied by burton power. Also has kent fkz2001 can kit fitted inc kent tappets and vale spring. Kent vernier pulleys in blue. For this id be looking for about £800
Also have newans ph3 cams for a zetec brand new never fitted £275
Obx 4-1 manifold and decat, the downpipe has been modified so it can run with a front mounted starter motor and has been run for about 100 miles so is still as new £150
Zetec roose motorsport/samco hose bit in blue, very good condition £140
New stage 2 cts box. comes with quaffe diff. For the spec see the cts website. These are around £1300 new and i ideally want £850 for it
Also selling both my motor bike carb set ups
zx9r carbs jetted to 2mm to run on the above engine, alloy inlet manifold made to suit the carbs so hoses line up perfect and have the correct level so the floats sit right, comes with megajolt ecu with base map and wiring/edis £350. Chester motorsport do this kit for over £750
Zx7r carbs again jetted to siut the above engine, alloy inlet made to suit the carbs so correct angle and hoses line up aswell. comes with omex 200 ecu mapped to suit my engine with all the wiring loom etc inc engine temp sensor wiring. R1 fuel pump £500
Both the above carb sets are ready to bolt on you would just need to alter the fuel lines to suit and some very easy wiring
engine and box would have to be collection only from Woking in Surrey, the carbs can be delivered by courier or collect from Woking or Byfleey
Spec is
JK12
33
Apr 26, 2021 12:09 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
