Re-torque longstuds after warm engine?
Old May 2, 2011 | 09:32 AM
Rockhound's Avatar
Rockhound
Default Re-torque longstuds after warm engine?
Some say torque the longstuds and then forget about them. Others say its important to check the torque on the studs and bolts after a few warm runs?
I have used the ARP grease and have tightened them 128NM as the instructions say, but is it really neccesary to check them again, and when should that be if it is?
Old May 2, 2011 | 07:47 PM
Personally I would recheck them next day when fully cooled down.
Old May 2, 2011 | 07:50 PM
Mark Shead's Avatar
Mark Shead
Whos make long studs.
Mark
Old May 3, 2011 | 04:31 PM
Rockhound's Avatar
Rockhound
I checked them today, and they were all still tightened correct. But it is always good to be sure. Should i check them again later on?
Old May 3, 2011 | 04:32 PM
Rockhound's Avatar
Rockhound
Mark
The long studs are mountune and the 4 studs in the end of the block are arp.
Old May 3, 2011 | 08:22 PM
If you've done a few warm runs, and they are same tightness I can't see them loosening now.
Old May 4, 2011 | 07:34 AM
Rockhound's Avatar
Rockhound
Ok. I did 3 warm runs and checked and they were all still tight enough.
Old May 4, 2011 | 06:13 PM
chrisa3's Avatar
chrisa3
Can you retorque standard head bolts after running the engine too. or is this just for studs etc
Chas
Sep 21, 2015 08:57 PM
muffster
13
Sep 3, 2015 09:40 PM
Roosie
Aug 13, 2015 07:40 PM
