Gearbox Mount
Old May 1, 2011 | 07:07 PM
chrisa3's Avatar
chrisa3
Default Gearbox Mount
Im fitting an exchange gearbox to my saff next week and wanted to renew the shitty rubber bush on the gearbox mount. I see Vibratechnics do an uprated one, but really dont want anyhting harsh. Does anyone know if the OE bush is still available or anywhere that sells a similar spec'd bush??
Old May 1, 2011 | 07:39 PM
tosh's Avatar
tosh
In my opinion I don't think the uprated are that bad I didn't notice much difference in noise, but you need to uprate the other mounts at the same time to give a similar bushing if that makes sense so that the engine and gear box are similar strength.
Old May 2, 2011 | 08:10 PM
Pretty sure that QH, and ford both still do this bush, certainly ford did around 3 years ago, as I bought one then.
Personally I would use the std ford one, in this position the last thing you want is a harder bush, esp when it's not needed, a new unsoft one will make a big difference, did in mine cured 90% of the 50mpg/5th gear vibration, the box being totally shagged didn't help of course!!
mjonathan24
Oct 29, 2015 10:39 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
