T5 Quick Shift
Old May 1, 2011 | 08:53 AM
reedy's Avatar
reedy
Gods Country
Default T5 Quick Shift
Has anyone tried this. Seem far too cheap !
http://cgi.ebay.co.uk/ws/eBayISAPI.d...RK:MESINDXX:IT
Thanks
Old May 1, 2011 | 10:25 AM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
If its to good to be true... It probably is.
Old May 1, 2011 | 12:59 PM
Looking at just his negative feedbacks, a lot are for short shifters.
I'm amazed if the can they can make a decent product for the money ?
Old May 1, 2011 | 04:03 PM
v man's Avatar
v man
Zee Germans are coming
does a good working t5 really need a quick shift
i think not lol
now the shitty sloppy 4x4 box does
Old May 1, 2011 | 04:09 PM
cossie604's Avatar
cossie604
Ive got a B&M shifter in mine that I bought cheap from the states. I had to heat up the shaft on that one and bend it over to suit our right hand drive cars. But tbh I'm thinking of switching back to the stock shifter some time this year as the T5 box doesnt seem too keen on being forced to shift gears any quicker than it was originaly intended
Old May 1, 2011 | 07:23 PM
The T5 isn't the quickest shifting box around, not the cossie version anyway, the chevy T5 is a lot better, it's easy to beat the synchro on the T5 as it is.
The only mod I did to my lever was to reposition it further forward by about 1 1/2", as I sit really forward due to short legs!!
Old May 1, 2011 | 07:28 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i was told by cts when i got my box not to use one as u tend to end up beating the synchro and damageing the box
Old May 1, 2011 | 08:22 PM
reedy's Avatar
reedy
Gods Country
Thanks for all the replys. Certainly food for thought.
Next question.
Which Close Ratio - Straight Cut, Syncro / Dog gear kit is recommended for the T5. I'm building a rally car so obviously not concerned about noise / harshness etc.
Quaife / Glebe etc ???
Many thanks
Old May 2, 2011 | 08:07 PM
If spending the sort of money you are going to need to, I wouldn't be wasting my time with a T5, try a T56 or similar, the original cossie T5 was only rated to 180bhp!!
Old May 3, 2011 | 07:48 PM
v man's Avatar
v man
then that shows how good they really are as there are plenty of 500 bhp cars using the standard t5 with no problems
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
