s1 engine same as s2 engine????
Old Feb 7, 2005 | 09:44 PM
cossie_wona_b's Avatar
cossie_wona_b
Default s1 engine same as s2 engine????
any 1 tell me if a series 1 engine is the same as a series 2?????
Old Feb 7, 2005 | 10:18 PM
bigpc's Avatar
bigpc
only thing that springs to mind is that the s2 have a water cooled turbo, not sure where they take the coolant from or where they feed it back in tho as i'm a S1 owner!
Old Feb 7, 2005 | 10:22 PM
cossie_wona_b
ta m8
Old Feb 7, 2005 | 10:35 PM
bud-weis's Avatar
bud-weis
Football Cwazy
the water pump is different also
Old Feb 8, 2005 | 07:17 AM
JesseT's Avatar
JesseT
Nearly every other part is different, but they are mostly equally good/bad and interchangeable.
Old Feb 8, 2005 | 05:14 PM
AJC's Avatar
AJC
inlet manifolds are 2 piece on s1's, plus the turbo different
Old Feb 8, 2005 | 06:58 PM
cossie_wona_b
thanks lads so i cant buy a s2 lump in stick it in??i gota find a s1 lump d'oh!!
Old Feb 8, 2005 | 08:15 PM
JesseT's Avatar
JesseT
Stick it in what? In to a S1? Yes you can, only trouble will be the water pump. Either fit a S1 waterpump or a S2 alternator mount and mk4 escort lower water pipe.
Old Feb 8, 2005 | 08:18 PM
scott's Avatar
scott
oil pump is better on a s1
Old Feb 8, 2005 | 08:38 PM
AJC's Avatar
AJC
the turbo is also water cooled on a s2 i think
Old Feb 8, 2005 | 09:42 PM
cossie_wona_b
its2 go into a series 1,but s1 engines are like rocking horse shit where as s2 lumps are like saxo's.....every body got 1!!!i thort its basicly the same engine so bang a s2 lump in and attach all s1 bits eg water/oil pump and s1 turbo etc etc?????
Old Feb 8, 2005 | 11:00 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yeah that's right. if you have the bottom end and cylinder head then just bolt everything you have onto it .
Old Feb 8, 2005 | 11:01 PM
bud-weis's Avatar
bud-weis
Football Cwazy
in fact i put a s1 engine into a s2 when i needed to replace mine a few years back, one less s1 engine for you
Old Feb 9, 2005 | 05:17 AM
JesseT's Avatar
JesseT
You can't and don't need to use a S1 oil pump on a S2 crank.
Old Feb 9, 2005 | 09:23 PM
cossie_wona_b
you boyz are legends!!!
right so basicly i get a s2 lump and bolt all s1 compents onto it but not the oil pump????
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
