Followers
Old Apr 30, 2011 | 11:04 AM
russ rs's Avatar
russ rs
Default Followers
Hi quick question. I have a efi and I mfi heads but the followers seem different the one in efi have a gold coller around them and mfi I don't. I would of thought they be the same. One on my car is sticking on mfi head was just gonna swap the set over but not sure now! Amy ideas why the diff?????
Old Apr 30, 2011 | 11:06 AM
haz87's Avatar
haz87
Probably just different brands. The lifters on efi and mfi were the same. HOWEVER, you should always replace lifters and cams together as they wear together. If you swap just the one lifter it will probably kill the lobe. Some people have got away with it tho (myself included) when just chancing the one lifter
Old Apr 30, 2011 | 11:20 AM
russ rs's Avatar
russ rs
Na I'd change the set but cam is a power developments one so don't wanna change that one follower sticking
Shows & Track Days
Apr 27, 2016 11:04 AM
steve.rst
Mar 15, 2016 08:01 AM
coscor86
Sep 20, 2015 01:21 PM
