Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
1978 Taunus (Cortina) TC2
Old Apr 28, 2011 | 09:51 AM
-wj-'s Avatar
-wj-
Default 1978 Taunus (Cortina) TC2
Hi guys,
My name is William and I'm kind of into old rearwheeldrive cars, and a nice old Taunus crossed my path and I decided to buy it
Even though the previous owner rattle canned it matte black, the interior is spotless and it's solid underneath, so a nice little project car !
It's currently running an lpg system on the stock 1600 engine. I have a sierra 2.0 engine that I want to swap into it, anybody here done that conversion ?
pics :
Old Apr 28, 2011 | 10:45 AM
bangerboy33's Avatar
bangerboy33
If they r both pinto engines it just a case of taking one out swapping mounts over and putting it back in
Old Apr 28, 2011 | 07:27 PM
As said pretty much just swap over, could think about a 5 speed box at same time ?
The LPG will need adjusting though most likely for best idle, depending on type.
Old Apr 30, 2011 | 02:34 PM
GrimV8's Avatar
GrimV8
Smokin'
If both are Pintos the down pipe needs to be longer to reach if my memory serves me well, due to the taller motor
Old Apr 30, 2011 | 08:47 PM
It's 16mm difference in height, so you'd have to be really unlucky for the 1600 one not to fit.
Old May 3, 2011 | 02:07 PM
-wj-'s Avatar
-wj-
unfortunately it's not the pinto engine but the dohc injection one, with ofcourse a 5 speed gearbox
will that be a straight swap, or will I have to fabricate my own engine mounts ?
Old May 3, 2011 | 08:14 PM
bangerboy33
That will b one big headache for not much go they really aren't that good in my opinion a sorted pinto would piss all over them with just a Carb and manifold change
Old May 9, 2011 | 09:16 AM
-wj-'s Avatar
-wj-
how can it be one big headache ?
I got it running on a pallet, so wiring is a piece of piss, I know how to weld, so engine and gearbox mounts are also no problem ?
I don't want the 2.0 dohc for all the go, mainly for much better economy
mainly interested in the propshaft, if that one will fit without modification !
Old May 17, 2011 | 10:59 AM
-wj-'s Avatar
-wj-
does anyone know about the propshaft ?
Old May 17, 2011 | 11:15 AM
Joshy's Avatar
Joshy
Dreamer
would imagin the prop would be fine as the gear box would stay.
Old May 18, 2011 | 09:03 AM
-wj-'s Avatar
-wj-
did you read the topic ?
I'm using a 2.0 dohc sierra engine with its own 5 speed gearbox.
So NO, the box doesn't stay...
Old May 18, 2011 | 10:33 AM
Joshy's Avatar
Joshy
Dreamer
oh sorry, thought you meant the 1600 had a 5 speed.
its not a big job to get a propshaft's length changed and balanced so get some quotes once you know the length you will need
Old May 19, 2011 | 09:08 AM
-wj-'s Avatar
-wj-
yes, I know
I was just wondering if anybody knows if the stock one will fit !
Surely somebody else has put this engine in this car before me ?
Old May 21, 2011 | 10:31 PM
-wj-'s Avatar
-wj-
Well, I went ahead and started the engine swap.
So far the only thing that looks slightly the same is the gearbox mount
Old May 22, 2011 | 05:11 PM
-wj-'s Avatar
-wj-
nope, even the gearbox mount needs fabricating lol
new engine in it's place :
Old Sep 29, 2011 | 11:28 AM
-wj-'s Avatar
-wj-
she runs, and brilliantly too !!!
ended up making my own enginemounts, gearbox mount and driveshaft. Fitted a volvo 245 radiator beneath the slampanel, no room for the old taunus one.
Managed to do a short run up to 178 km/h on gps, and the driveshaft didn't start wobbling etc
I've used icehockypucks as enginemounts, but they are a little bit too stiff for a daily driver. Gonna try to find something that's got a little more "give" in it. Also retro fitted the lpg system, just waiting for a 60mm diameter lpg mixer to fit in the intake piping.
20/20 vision
Sep 29, 2015 11:27 AM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
Vacuman
Sep 11, 2015 11:37 PM
RockinRein
Aug 19, 2015 07:08 PM
Sultzi
12
Aug 16, 2015 01:08 PM
