cossie coilovers
Old Apr 27, 2011 | 08:48 AM
BIG MULL's Avatar
BIG MULL
Default cossie coilovers
hi, could any of you fine gentlemen tell me if these are 2wd rear coilovers or 4wd rear coilovers or are they both the same?
Old Apr 27, 2011 | 04:02 PM
99% sure they are 4wd, the only difference is the width of the rear/bottom mounting eye, it is wider on 4wd, but normally same rates as 2wd, just the 2wd and 4wd have a different width spacer, maybe the 4wd ones use a high angle spacer each side, and the 2wd don't.
Easiest way is just measure the width and compare with your car.
If they are 4wd and you need 2wd it is easily sorted, as it is the other way around.
Old Apr 28, 2011 | 11:24 AM
BIG MULL's Avatar
BIG MULL
cheers tabetha, i was going to buy them but think ill leave them now if there for a 4wd bud.
Old Apr 28, 2011 | 07:36 PM
VERY easy to sort out if for 4wd and you're 2wd, at the worst spacers would need 1/4" machining off each end, send to me and I'l do it FREE for you.
Old Apr 29, 2011 | 10:05 AM
BIG MULL's Avatar
BIG MULL
the lad has sold them now tabetha, but much appreciated for the offer buddy
Old Apr 29, 2011 | 03:45 PM
Mark RS's Avatar
Mark RS
The rear coil overs are the same fitment on both 4wd and rwd cars! Tab is wrong.
Old Apr 29, 2011 | 06:18 PM
Try reading my whole post, the bottom eye fitting width is different from 2wd to 4wd, this can be easily sorted if a universal, ie spacer system is not utilised, I've cut enough down by 1/4" per end to know.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
