REV counter help
Old Apr 25, 2011 | 09:13 PM
matthewsimone's Avatar
matthewsimone
Question REV counter help
Evening all, when out in the S2 today ive noticed that when going along at a steady speed (say 60) the rev counter seems to be fluctuating a little bit? not bouncing all over the place but just going up and down between a couple hundred revs? also have recently had the old back lights flickering issue which a mate noticed when following me down to Central day but ive cleaned all connectors etc and they are working fine again now could my rev counter issue also be down to dodgy connector/earth etc
Matt
Old Apr 27, 2011 | 08:21 AM
Cameron's Avatar
Cameron
Mine is also dodgy, seems sort of 'sticky' and doesnt move up or down smoothly, pretty sure its not reading the correct revs either.
Old Apr 27, 2011 | 06:04 PM
PETEDUDE007's Avatar
PETEDUDE007
SNAP! mines is like 2000rpm down shud be like 6000rpm says 4000rpm damn things! want it fixed! ahhhhhhh
Old Apr 30, 2011 | 01:56 PM
matthewsimone
Still not managed to sort this issue but after more research im now being told it could even be something as serious as gearbox issue
going to go check all wiring on that circuit plus earths etc to rule that out
anyone heard/know much of these issues ?
Matt
Old Apr 30, 2011 | 05:21 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Matt
bugger all to do with gearbox, who ever told you that doesn't know what they are talking about, both are mutually exclusive
it's more than likely an old wiring issue with an earth that is causing issues.
if it misreads throughout the revs there is an adjuster under the rev counter to correct the reading multiplier (handy for changing to efi when you only have a single supply from coil pack).
do what i did and buy a stack one, mucho coolness
Old Apr 30, 2011 | 05:28 PM
dbanbery's Avatar
dbanbery
yeah second that it will be a dodgy earth. turn on your lights and see if the tacho moves when its ticking over normally. my red one used to go up by 500 rpm when you switched the lights on, and used to go up when you used the leccy windows too.
Old Apr 30, 2011 | 06:04 PM
matthewsimone
cheers for replies, yeah revs do drop a little when lights turn on or electric windows operated etc, cleaned up all earths and connectors today so will take her for a spin tommorrow, see how she is, my old man said it could also be the inline supressor thats in the green wire from coil that sits near inner passenger wing possibly breaking down these apparantly supress the electrical noise/interferance from radio etc which in turn stops the rev counter going nuts !
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
