Good rear brake setup??
Old Apr 25, 2011 | 04:31 PM
Staffi's Avatar
Staffi
Default Good rear brake setup??
As above folks, i'm after a decent rear setup, not AP's as o have those new on the fronts, just something abit more substantial than the standards.
What have you on yours folks and any recommendations pleaseeeeeeee??
Pete..
Old Apr 25, 2011 | 04:40 PM
D16PJM's Avatar
D16PJM
with what you have on the front standard size discs and uprated pads should be o.k, cheapest option as well, just drill and groove discs or similar as well.
Old Apr 25, 2011 | 04:58 PM
Staffi's Avatar
Staffi
Cheers Pedro.............
Who's best to buy from mate do you know??
Old Apr 25, 2011 | 05:01 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
id just use standard 4x4 stuff
Old Apr 25, 2011 | 05:07 PM
Staffi's Avatar
Staffi
James, would i need to fit 4x4 backing plates & discs guards with that conversion??
Old Apr 25, 2011 | 05:11 PM
ajamesc's Avatar
ajamesc
na all gos straight on and being vented they dont get so hot mine did have the splash guards on but they were rotten so i took them off and dont have any now
Old Apr 25, 2011 | 05:20 PM
Staffi's Avatar
Staffi
Excellent, i may go that route then, where's the best place to buy them from James??
Removing the spalsh guards, what's involved in that pal as mine are abit rusty tbh and look naff....
Old Apr 25, 2011 | 05:25 PM
ajamesc's Avatar
ajamesc
Any good factors or ebay will sell 2 calipers and a set of discs cheap but as u have to undo the drive sharft nuts and drop the wheel bearing carrier u may as well do the rear wheel bearings as well but its an easy job if i remember right there held on by 4 bolts under the wheel bearing carrier! some bodgers cut them off but why bother if its your own car lol
Old Apr 25, 2011 | 05:26 PM
Staffi's Avatar
Staffi
Cutting off sounds easier though mate...
Cheers for the info bud, appreciate that...
Old Apr 25, 2011 | 07:08 PM
Just take out the 4 hub/bearing carrier bolts, then a sharp chisel and a minutes work they are off!!
Old Apr 25, 2011 | 09:11 PM
Ridgey's Avatar
Ridgey
Are the rear brakes under performing then Pete ? Or can you just not help yourself
If you are going to the cost of changing the calipers to 4x4 you may as well get a 300mm kit (disk/bell/caliper mount) from someone like Nuts Rus.
Or just leave it alone
Old Apr 25, 2011 | 09:13 PM
ajamesc's Avatar
ajamesc
but that costs loads more than a 4x4 set up and the 2wd set up with non vented discs can get hot quite fast
Old Apr 28, 2011 | 12:44 PM
Ridgey's Avatar
Ridgey
Need the calipers anyway to go 4x4 so it's just the disks/bell/calpier spacer.
It wouldn't be loads more, Pete's loaded anyway
Old Apr 28, 2011 | 06:18 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
lol if your wanting to refit spash gaurds pete , i have a mate re fabricating new 2wd and 4x4 jobbies
also made a tad larger to accommodate 300mm conversions if needed
beef
Old Apr 28, 2011 | 07:46 PM
Someone on here pondered the idea of fitting FRS(mk1) 325 discs to the rear, from memory the offset was only 1 mm different and disc thickness was so close it would work, easy to make up some spacer plates out of 5mm mild and 4 spacer tubes to go with them, worth thinking about ?
original
Apr 28, 2026 05:20 PM
markk
Dec 2, 2021 06:59 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
