550-600bhp on a YB, whats needed?
Old Apr 24, 2011 | 08:33 PM
crumpet's Avatar
crumpet
Default 550-600bhp on a YB, whats needed?
Obviously a decent turbo like a gt35r,But what else is needed, what injectors? what head bolts, what work to head, what pistons, what rods, what cams, what management, what clutch, etc!
Old Apr 24, 2011 | 08:39 PM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
Copy rods car! Cant go wrong and you know it will be fast!
Old Apr 24, 2011 | 08:42 PM
J1mbo's Avatar
J1mbo
B1mbo
Decent turbo and a gt35 don't go in the same sentence far far better turbos about for 600bhp
Proper h section rods with cps
10 long studs, not your shity arps
A lot of head work both sides
Cams
Inlet 2wd ex manifold
I'd put it on pectel and run a twin plate paddle clutch but a ap 6paddle should do
crumpet's Avatar
crumpet
just read up a few threads, a gt30 at 2.5 bar with a decent spec YB would be best option for my budget
Jim what power could a gt3076r make on a Yb,forged bottom end, wrc gasket, ab07-bd14 inlet cam, ported head, siemens 83lph blacks, 6 long studs,, and On standard L6?
Old Apr 24, 2011 | 08:44 PM
Mark Shead's Avatar
Mark Shead
Cams
The GT35 is a awsome turbo and the GTX35 is even better.
Mark
Old Apr 24, 2011 | 08:45 PM
J1mbo's Avatar
J1mbo
B1mbo
Hahaha I awaited you Mark
Mark Shead's Avatar
Mark Shead
I would go with the GTX3071 or a BW EFR.
Mark
Old Apr 24, 2011 | 08:47 PM
Nash's Avatar
Nash
Cake lover!
Budget and 600bhp are not the first two words that spring to mind when thinking about this lol.
Old Apr 24, 2011 | 08:48 PM
J1mbo's Avatar
J1mbo
B1mbo
No where near 550-600 lol
Don't piss about with mild cams get a set of cams from someone who's been there and done it
Depends on who ported the head too but 530 at 2.1 bar I imagine,
We've seen 545 at 2.2 bar with out new inlet
I wouldn't say running 2.5 bar is the best way to go, slightly bigger turbo and 2.2 bar there's turbos out there that you won't loose much down the bottom
Gt30 even in the big ex housing suffer with high back pressure at higher rpm too we dine a lot of testing with them
Old Apr 24, 2011 | 08:50 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
500-550bhp territory.
and On standard L6?
I won't go above 400bhp on L6! Strongly recommend changing...
Old Apr 24, 2011 | 09:01 PM
crumpet's Avatar
crumpet
learn somethin new everyday eh!
best road going spec would be gt30 no doubt, as with over 450bhp in a road car will probably be too much anyway, Just been reading chips posts.
Old Apr 25, 2011 | 03:39 PM
rsmark86's Avatar
rsmark86
my spec mate...
200block long studs
forged pistons with big valve cut outs (standard compression)
lightened and balanced
full race spec head
custom profile cams to suit spec ( mark^^ could do them)
gt35 with external waste gate and screamer pipe
reyland modded 2wd manifold
83lbs siemens
r&b motorsport inlet (hart is the best tho )
big cooler ect ( spec r bar and grill type is the best)
big spec r breather set up
autronic sm4
and about 14k lol
and should be well over 500bhp but if i had the money and fitted a hart plenum and spec r cooler it would be close to 600bhp
MARK mine is nearly done now and ive put a inlet on and a bigger breather so will book in this month for a remap
Old Apr 25, 2011 | 04:29 PM
J1mbo's Avatar
J1mbo
B1mbo
Originally Posted by rsmark86
my spec mate...
200block long studs
full race spec head
83lbs siemens
autronic sm4
and about 14k lol
The hart inlet will give you no more power over the r and b sweedish
Neither will the cooler!?
Old Apr 25, 2011 | 04:42 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
why do they make so much more on guys like rod and ads then?
Old Apr 25, 2011 | 04:47 PM
J1mbo's Avatar
J1mbo
B1mbo
Thats like comparing apples to oranges, the engines are completely different?
For out and out power theres no difference,
We have proved the sweedish inlet to be just good at 700 no more, they're not the best inlet but they make the peak figures
The hart, when modified will make that power, and more
So at 525 bhp both are having a easy time so to speak
Old Apr 25, 2011 | 04:52 PM
ajamesc's Avatar
ajamesc
i see what your saying but if said cooler cools better and more efficiently and said inlet flows better and more efficiently isent it going to keep its bhp for longer when hot and make peek boost faster then be better on all power levels
Old Apr 25, 2011 | 04:53 PM
J1mbo's Avatar
J1mbo
B1mbo
I'm talking about peak figures
Yes the cooler will keep all it's power there for longer, but peak fig won't change
Old Apr 25, 2011 | 08:21 PM
G 74F 00's Avatar
G 74F 00
Thumbs up
hi what are the reasons not to use a l6 over 400bhp?
Old Apr 25, 2011 | 08:54 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Thats just made me spill my tea . How can 450bhp be too much.
Old Apr 25, 2011 | 08:56 PM
J1mbo's Avatar
J1mbo
B1mbo
For someone not used to a 2wd car rod a punchy 450hp can soon catch you out!
And where I live a 450hp low lag engine will beat anything
That's why I'm having one in mine lol!
Old Apr 25, 2011 | 09:02 PM
bad boy rs's Avatar
bad boy rs
my 395 bhp & 410 lb ft is plenty quick for me cant imagine what 550+ is like
Old Apr 25, 2011 | 09:08 PM
bad boy rs's Avatar
bad boy rs
whats up with the sweedish inlets out of intrest ?
Old Apr 25, 2011 | 10:07 PM
crumpet's Avatar
crumpet
exactly rod, Quickest car ive drove is a 4x4 proton evo rust bucket or a stage 3 saph!
Like jim and paul have said low lag punchy 400-450bhp is where its at!
Old Apr 26, 2011 | 04:55 AM
BRAMMER's Avatar
BRAMMER
Couldn't have put it better myself Adam - i know how much money i have in mine and i am know where near that sort of figure, i wouldn't know for sure but i would guestimate the bill for a complete 600 spec build to be around Ł25-30k maybe more depending how fancy the parts are
Old Apr 26, 2011 | 07:32 AM
MAD Ade's Avatar
MAD Ade
You also have to bear in mind the transmission, that wil cost five grand minimum.
Old Apr 26, 2011 | 08:29 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Fit a standard beam back on your car and you'll soon remember
Depends what people are using it for ultimately though, if all you want to do is put your foot down on dual carriageways and motorways in high gears then you'll always want more power, if its making genuinely quick progress down twisty roads though even 450bhp is still 100bhp more than a WRC car dont forget!
Old Apr 26, 2011 | 08:34 AM
Staffi's Avatar
Staffi
So WHY have you put a thread up asking for 600bhp then??
Old Apr 9, 2015 | 06:52 AM
SGP's Avatar
SGP
10 Year Member
Anyone used a 4G63 engine inside
Old Apr 9, 2015 | 07:30 PM
turbotrev's Avatar
turbotrev
If it helps you my basic spec is
200 block,
Cosworth Pistons,
Neil Roper head,
AB07 and bd16 cams,
GTX30 turbo,
External wastegate,
Airtec cooler,
Hart inlet,
L8 management,
And it done 540 on both an engine dyno and rolling road
Cheers Paul
Old Apr 9, 2015 | 08:12 PM
gjh's Avatar
gjh
Instead of a YB in a cossie? No point, cant see it being any cheaper or more reliable (believe it of not a properly built and maintained YB is a reliable motor!).
Old Apr 9, 2015 | 08:43 PM
ajamesc's Avatar
ajamesc
Deep pockets lol
Old Apr 9, 2015 | 09:21 PM
Mark Shead's Avatar
Mark Shead
I have done plenty with that engine
Mark
Old Apr 11, 2015 | 10:12 PM
The Enigma's Avatar
The Enigma
Mark
Is it an cheaper engine to tune to big power (500bhp+) than the YB?
Old Apr 12, 2015 | 07:44 AM
Mark Shead's Avatar
Mark Shead
It ends up being about the same.
Mark
Old Apr 12, 2015 | 02:26 PM
The Enigma's Avatar
The Enigma
Mark
Interesting.
Have you had any dealings with the 3SGTE that is in the Celica GT4's and MR2 turbos. Good engine?
Old Apr 12, 2015 | 02:43 PM
gjh's Avatar
gjh
Think Fensport are the people to talk too with celica GT4/MR2 engines.
Old Apr 12, 2015 | 03:12 PM
Mark Shead's Avatar
Mark Shead
Interesting.
No as main dealings with engines are Evo Yb Porsche.
Mark
Old Apr 12, 2015 | 03:31 PM
SGP's Avatar
SGP
10 Year Member
What compression and how thick is the gasket ?
I was thinking of buying 2mm head gasket .
Old Apr 12, 2015 | 03:38 PM
SGP's Avatar
SGP
10 Year Member
I belive the 4G63 is more reliable and it can Rev crazy. Just a though as I am pretty familiar with them .
Old Apr 12, 2015 | 03:44 PM
Mark Shead's Avatar
Mark Shead
If you are talking about the Evo engine I only use a 1mm hks head gasket on all my engines over 600hp.
Mark
