auto gearbox help!!!
Old Apr 24, 2011 | 02:44 PM
mgbrs's Avatar
mgbrs
Question auto gearbox help!!!
when i select D or R on my saph auto gearbox, it takes around 30secs to a minute for the gear to select and engauge, and even when in it seems to come out of gear!! any help or advice would be appreciated.
cheers in advance
Old Apr 24, 2011 | 03:53 PM
mk2 cossie's Avatar
mk2 cossie
is it the 4speed auto box?
if its the A4LD box, they like a fluid and filter change
may also be worth re adjusting the brake bands if you have a square socket as well
Old Apr 24, 2011 | 04:16 PM
mgbrs's Avatar
mgbrs
cheers pal, and yeah it is the 4 speed, yeah going change the fluid and filter, where are the brake bands situated?? and on closer inspection its leaking fluid!!
Old Apr 24, 2011 | 05:37 PM
If the leak is anything more than just trivial, it needs fixing.
Brake bands will not cause this, they are not even used until it is moving.
Check your fluid level first, is the fluid nice and cherry red, if brown and smells and tastes of acid then the brake bands are starting to break up.
It has nothing at all to do with the brake bands, these just hold clutch drums still when in gear so slippage doesn't occur, but yours is almost certainly a pump/pressure problem.
The brake band is adjusted, if you know what you're doing, if not DON'T, by turning the 3/8 square adjuster sticking out the side of the box, when set correctly the car will free wheel in 4th gear when easing off accelerator.
If the filters never been changed do it now with fresh fluid, you can also get a adjustable vac can for these, improves the shifts, and the valve body parts(valves/springs) can be swapped to make more sporty, as I did, although there is not a specific kit available.
If keeping the car fit a TRANS cooler, after the rad cooling, this cuts down massively on heat, and makes it last longer as well.
I fitted a winnebego motorhome trans cooler and cut 65C temp out, my left foot was roasting on a hot day from the trans heat, this box was designed to use draughted air, in the us cars, but no draughted air provided in european cars so they benefit massively from a cooler.
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
AJC
Oct 1, 2015 06:47 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
