fault codes on focus st 225
Hi folks
hope someone can help, ive got a 56 reg focus st 2.5 with three different fault codes p0805 clutch position fault, B2163 clutch position fault, U1900 CAN communication bus fault receive error. also intermittently i get a esp failure which results in a sudden loss of acceleration untill you lift off then its fine but with the esp warning light on, it stays on untill you restart vehicle
any help will be appreciated
DixieTheKid
Sep 14, 2015 09:04 PM
Si B
Sep 12, 2015 06:49 AM
