Cossie boost 'cough'
Old Apr 21, 2011 | 10:42 PM
groomers's Avatar
groomers
Default Cossie boost 'cough'
Hi guy having a few issues with the saph, started off with complete loss of power over 7 psi boost, had new phase sensor and cps fitted (gapped) and plugs hard wired on bulkhead, all plus on engine were contact cleaned and earths cleaned up.
Misfire then got better would get to 10psi also noticed exhaust manifold and downpipe glowing red after nursing it home off boost stuck it back in the garage in a strop!
Now fitted a new 044 pump with decent loom and relay etc, and made and fitted a junction box on batt (now round post) also have fitted a new act sensor.
Still not sorted have full boost back 17 peak 15 held but get an occasional cough from it, hard to explain but a slight miss not a full blown one.
It has had most sensors replaced new fuel etc.
Is there anything obvious I have missed oh plugs rotor arm and cap have all been cleaned as well.
Old Apr 22, 2011 | 06:12 PM
A common connector to give trouble is the female(have to be wouldn't it!!) side of the CPS, ie the loom plug, over the years the terminals lose their tension on the male pins of the sensor plug, worth a check and see if there is any dizzy side to side movement.
Old Apr 22, 2011 | 08:41 PM
groomers's Avatar
groomers
Forgot to say that the dizzy bearings are fine checked all that out when phase sensor was fitted. Will check cps connector over the weekend at somepoint.
Thanks
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
