What is a t34?
Is a T34 a T3 with T4 rear housing?
Been offered one and its been sold as a T34, but im confused and i didnt realise it was that (If it is of course)!!
Joe.
Joe.
A larger back housing will spool up slower, won't get as hot and can run high boost as won't stall dew 2 the fact they can flow more air.
If a t34 and a t35 are the same y didn't they just call them t34s? A t34 is a modified turbo using components, where a t35 is a product that has been manufactured and sold.
But as I said before, might be wrong!!
Correct, T3/4 has a larger compressor wheel and housing than the T3 series has in its range. In fact, the compressor wheel is from the T4 range...
thats y its a t35 as stated in the spec list?
sorry just went threw all of this years ago and people still get confused.
Garrett's terminology for the Escort Cosworth turbo is a T03/4B. The T35 doesn't exist as an off the shelf item for petrol applications but there is diesel T35 for a DAF truck.
The 3/4 comes from being half way between the T3 range and the T4 range.
Cilly, the word you were looking for was “sure”!
It's not a T3 or a T4. It's a model of turbo which fits in between a T3 and a T4, hence the name T03/4B.
It has a unique .48 turbine housing, a 55 trim compressor wheel with a .63 compressor housing. Options being a .63 turbine housing and a 60 trim compressor wheel.
Remember, that the compressor "trim" does not describe the sixe, only the square of the inducer/exducer ratio. So, a 55 trim T4 compressor is still bigger than a 55 trim T3 compressor.
Russ Payne
Sep 25, 2015 08:29 PM
