Rs turbo boooost
Old Apr 19, 2011 | 07:43 PM
Bransby's Avatar
Bransby
Default Rs turbo boooost
Hi I've fitted a boost gauge to ma project and it's always at -20 psi when it boosts it just get to 0psi and ideas ? Also when firsts starts sounds like it's on 3 cylinders and lumpy as and stops then does same again but warms up and is sound, any ideas ? Cheers Ryan
Old Apr 19, 2011 | 07:52 PM
Jonny RS's Avatar
Jonny RS
On idle they do sit around -20psi mate.
Does it feel like its boosting properly and pulling away?
Old Apr 19, 2011 | 08:52 PM
Bransby's Avatar
Bransby
Ive only taken the car up the road once since the conversion from a 3i to rs, so it's first time I've been in a rs turbo, it definatly seemd to pick up like the turbo liked in and the dump valve did his between gears but since I've fitted the gauge it seems like it can't of been boost correctly at all, could it be the actuator ? I do have a bleed valve that isn't fitted but poped it on just to see if the boost was rite down or something but it didn't alter the boost at all jus seemed to flick upto 0psi cheers Ryan
Old Apr 19, 2011 | 09:26 PM
Jonny RS's Avatar
Jonny RS
First piece of advise is to get that bleed valve off now mate. If your using one of them only let a tuner put them on and set them up or else their is a chance the engine will go pop due to overboosting.
If it was a conversion i would double check all boost and vacum hoses.
You might also want to get a tuner to take a look if that all looks fine. My local tuner only charges £65 for a basic set up session.
Old Apr 20, 2011 | 07:00 AM
Rogeyboy's Avatar
Rogeyboy
Check for a vac/boost leak... The gauge might be causing a leak?
Also the actuator might not be adjusted very much!
Old Apr 20, 2011 | 08:29 AM
martysmartie's Avatar
martysmartie
You not going to see any boost on idle, only vacuum which is what you have, are you using the correct dump valve?
Martin
Old Apr 20, 2011 | 09:11 PM
Bransby's Avatar
Bransby
Hi I'm using a baileys dump valve, I've checked all vacume hoses and they seem fine, also the car seems to fire on 3 at first then runs sound after few seconds but it hunting, guesing this is a sighn of a air leak? And yes I'm def guna take it to my local tubers and get it set upbut don't want to take it of the turbo is nackerd in the first place or there's a air leak, how can you test for air leaks? If the system I's a vacume I gues leak detector stray or soapy water would be a waste of time as no bubbles would apear? Also how do you check the wastegate? Cheers lads Ryan
Old Apr 20, 2011 | 09:32 PM
Jimmyc's Avatar
Jimmyc
Not really a waste of time with the soapy water spray matey, I think the fluid temporarily seals any leaks and youll hear a change in revs.
Old Apr 20, 2011 | 09:41 PM
martysmartie
It is the correct "Twin Piston D/V" for RST though? Using WD40 sparingly round manifolds etc when engine is running is useful for detecting an air leak, if so the revs should change.
Martin
Old Apr 21, 2011 | 10:11 AM
Bransby's Avatar
Bransby
Cheers for that lads I'll try both tnite and let you kno and I'm not sure if it's a twin piston, how do you tell mate ?cheers Ryan
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
