Engine fuel Cut help :-(
Old Apr 19, 2011 | 04:56 PM
Hansenturbo's Avatar
Hansenturbo
Unhappy Engine fuel Cut help :-(
I had my car for MOT my rst is running cossy mag
we turned the co down from 12,8 to 8,8 we could not get it lower
:-/ but i was in luck he did not mesure the co but i also lowered the boost to 7psi
but later when i turned up the boost to 16psi
and ajusted the co up the car now makes a fuel cut
when it comes over 2500rpm :-(
could it be an ajustment problem?
Help.......
Old Apr 20, 2011 | 12:23 PM
Hansenturbo
Ect sensor or mapsensor?
Old Apr 20, 2011 | 02:26 PM
sir-squeaky's Avatar
sir-squeaky
Help.......
Hello yea this dose sound like a adjustment problem i would turn the co down again then try see if it seams to still do it and slowly keep ticking her up untill you get it just right
Old Apr 22, 2011 | 07:50 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Whos chip is it running.
Old Apr 23, 2011 | 03:48 PM
Hansenturbo
A chip by a guy called cossieclint never got a problem
all these years i have run with it change the blue water temp sensor
but with no luck cos before the co was 12.8 and could only come down to 8.8
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
