MSD closed loop
Old Apr 18, 2011 | 07:16 PM
mattman1234's Avatar
mattman1234
Default MSD closed loop
as above,how can i tell if it is working,what should the voltage be on the output of the lamda on idle
any help
thanks matt
Old Apr 19, 2011 | 06:37 AM
oldford's Avatar
oldford
Oxygen sensor should be switching between 0.1/0.2 volt and 0.7/0.8 volt.
That apllies to idle and partial load.
What signal do you get?
Old Apr 19, 2011 | 07:21 PM
mattman1234
yep,i get .7 volts on idle
the afr sits around 14.4 when its up to temp
JK12
33
Apr 26, 2021 12:09 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
