Edis or internal driver?
A friend is using a edis to run his ms1. Is there any advantage or adding an internal spark driver over the EDIS? The wiring will be simpler but is that it?
Do you not have less ignition control when using edis?
The next megasquirt i build will have external coil drivers, apparently much less noisy, and a different ground to the ecu.
Rob,
Rob,
Ahh okay, but im sure the edis module will set dwell pretty perfectly with a ford coil pack!
Yes all is good, mine will be left alone, but i do still see a little noise which i believe comes from the ignition drivers, i would prefer it if there was no noise.
Rob,
Rob,
mk3ste
Oct 17, 2021 10:09 AM
155lee
Oct 24, 2015 11:11 AM
