Reversing switch connection?
Right i've been a spaz and forgotton where my reversing light switch connects into the main loom
I've connected the extension loom from the grearbox up, but i can't see where this plugs into the main car loom? Is it inlet side or exhaust side?
Mine is a 2wd sapphire so maybe different but it's on the inlet side of the engine for definite. I think from memory, it's against the bulkhead by the corner of the battery tray? If not, it's a part of the engine loom. That sounds odd but to explain, I'm just about finishing re-building mine from a stripped rolling shell, and I used my old engine loom from my prior cossie. Before re-fitting it I had the loom tested and re-wrapped in different colour tape, and I clearly remember the reverse switch wire being re-wrapped in the same colour. And it was only the engine loom and one earth strap I replaced so therefore it is definitely either part of the engine loom (by that I mean the wiring that goes through the large rubber grommet in the bulkhead, that the ECU plug goes through, as I removed the loom complete with grommet) or up by the battery tray as a seperate wire to the loom.
Hope that makes sense after all that! Have tried to find a pic showing it but no luck yet.
cheeRS
cheeRS
100% inlet side, with a massive connector, with two very thin looking lonely wires in it, the connector looks to be about a 6-8 wire connector but uses only the two wires, I had to move mine yesterday when bolting my hydraulic bleed fitting to the old clutch cable hole, as it was in the way.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
rsguy
44
Sep 29, 2015 03:29 PM
