pipe from ecu??
Old Apr 15, 2011 | 06:25 PM
dirtysteve's Avatar
dirtysteve
Default pipe from ecu??
hi peeps, on my s2 the small vac? Pipe from the ecu doesnt go anywhere and isnt blocked off, would i be right to assume it should go to the valve on top of the gearbox?, and would it have been removed for a valid reason?, your help would be appreciated, Steve
Old Apr 15, 2011 | 06:26 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
That sounds frighteningly like the map sensor pipe on some ecu's but cant remember what an S2 one is like as I dont have a lot to do with Rs Turbos if I can help it, lol
Old Apr 15, 2011 | 06:33 PM
mk1trb's Avatar
mk1trb
Boost Junkie
thats the map sensor pipe, get it connected to the one of the top inlet ports asap as your engine dont know how much boost its running.
Old Apr 15, 2011 | 06:34 PM
mr_joe0606's Avatar
mr_joe0606
vac pipe go's from ecu to inlet manifold.
Old Apr 15, 2011 | 06:47 PM
dirtysteve's Avatar
dirtysteve
please excuse my ignorance as it's my 1st turbo, where should it go on the inlet?, and could that explain why it had a hole in a piston when i got it?,
Old Apr 15, 2011 | 06:54 PM
mr_joe0606's Avatar
mr_joe0606
there are 2 inlets at the top of the inlet manifold above the throttle body
Old Apr 15, 2011 | 07:05 PM
dirtysteve's Avatar
dirtysteve
cheers, thanks for all your help,
Old Apr 15, 2011 | 07:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes that would be exactly why it had a hole in the piston when you got it!
Old Apr 15, 2011 | 07:34 PM
Chip's Avatar
Chip
Hell yeah!
For god's sake when you have it back together and working take it to someone who knows what they are doing to check the fuelling over.
Old Apr 15, 2011 | 07:46 PM
dirtysteve's Avatar
dirtysteve
Originally Posted by Chip
Hell yeah!
i definitely will, i dont want that again,
Old Apr 15, 2011 | 08:23 PM
Oranoco's Avatar
Oranoco
On the plus side I find my holed piston a great paperweight at the office and it's a good talking point with people who think by checking their own tyre pressures they are a dab hand with cars
Old Apr 15, 2011 | 08:39 PM
liam-rst's Avatar
liam-rst
shit happens
bit like this one lol, although caused by a valve droppin its head poss due to fuelling too lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mpilk
Sep 27, 2015 09:21 AM
