water pump 1.2 zetec engine remove & Replace
Hi i have a lowly 1.2 1996 fiesta si fitted with a 1250cc 16 valve zetec engine and power steering. The water pump has siezed solid. I have been told you can replace it without removing the cam belt as i had this done last year. Plus how do i get a auxilary belt off i cannot see how to slaken any thing. If some one could give me a run down on how to remove and replace the water pump i would be greatefull. I know you guys have the souped up fiestas but can some one help a old 60 year old out. Cheers f1bash
Hi i was very lucky no over heating pulled up every thing great then horrible noise smoke from belt turned engine off could see water pump pully was siezed cut belt of engine sweet as a nut. I know that it states in the manual timing belt needs removing but i have seen about three posts where with a bit of fiddling the pump can be installed without taking timing belt of. If any one can give me a run down how to take the pump of and replace it would be a great help. f1bash
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
