Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Compressor-home useage
Old Apr 15, 2011 | 12:43 PM
studabear's Avatar
studabear
Default Compressor-home useage
I'm thinking of buying a compressor for use at home, will be used mainly for air ratchet and impact gun. As I want to bring my air tools home for when the engine and gearbox have to come out of my cabriolet.
What size compressors are other users using, and any recommendations etc
I would like something semi portable.
Old Apr 15, 2011 | 01:05 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Ive got a 3hp one with a 150 litre tank, that works really well.
Im sure you could go smaller though and still be ok if you dont mind it cutting in and out a lot more often.
Old Apr 21, 2011 | 09:50 PM
Shilly's Avatar
Shilly
http://www.screwfix.com/p/michelin-m...sory-kit/24375
got the older version of this does a few jobs well but it does go off its nuts after a few bolts i would go for a 50 + ltr one in the future though or just go for a snap on electric impact gun
Old Apr 29, 2011 | 09:15 PM
dakar's Avatar
dakar
buy a belt driven one as they are generally better quality than a direct drive one and also are a little quieter
Old May 8, 2011 | 09:13 PM
bunnymofo's Avatar
bunnymofo
iv got one exactly the same as this. http://cgi.ebay.co.uk/Clarke-Industr...item4aa68eab0a
its pretty good, i can spray etc. but if im using spray gun, air fed mask and someone is using blow gun / rattle gun it cycles quite often
Old Sep 29, 2011 | 04:13 PM
daddy2coull's Avatar
daddy2coull
i'd say a 3hp with a minimum of 50l tank would do you good. but i would go for 100l, that will give you a good all round compressor
Old Sep 30, 2011 | 07:58 PM
twister's Avatar
twister
4 HP 200 litre tank sealey.
Old Sep 30, 2011 | 10:58 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i have a 2hp clarke 50litre one, works fine, but i'm looking for a 100/150ltr 3hp one for my bigger impact gun/da sander to run a little better.
Old Oct 4, 2011 | 12:06 AM
mrjenrst's Avatar
mrjenrst
what power supply you got in? 32amp minimum
opposite lock
Aug 19, 2015 09:06 AM
RSmark84
Mar 20, 2013 07:08 PM
CosRush
12
Oct 29, 2006 05:41 PM
