Double Din Depth?
Old Apr 15, 2011 | 09:52 AM
jelly-monster's Avatar
jelly-monster
Exclamation Double Din Depth?
Hi Guys,
I have just bought a Ford Focus 1.8 TDCI 115PS 03 Reg Zetec.
Just need to know what the maximum double din depth is.
And would this give room for wiring too?
JM
Old Apr 15, 2011 | 09:59 AM
carlfiesta999's Avatar
carlfiesta999
Theres plenty of room down the back of the dash for normal wiring.
Depth wise, i thought most double din units were mostly the same depth, same with single din headunits (which you can use too).
Old Apr 15, 2011 | 10:10 AM
jelly-monster
ahh, should have explained.
I'm not looking to put a standard head unit into it, I'm looking to put a mini-ITX computer in there however I need to know how big I can make the case.
Old Apr 15, 2011 | 10:33 AM
Blue-Oval-Bass's Avatar
Blue-Oval-Bass
I think in your case its best to pull out the HU and measure up.
Think there is more room below the rear than at the rear face so cables exiting the rear underside might help.
Is this pc system for mass music storage ? just curious as i fancy the idea but im not pc techy enough to do it.
Quite a few in-car pc set ups on TA that seem to work well.
Old Apr 15, 2011 | 10:41 AM
jelly-monster
I think that will be best.
I'm doing it for a few things, I had a carPC in my old car but never did too much with it other than music. It also looked awful, the screen was just sort of stuck on the dash.
I'm hoping I can get an all in one sort of thing on a 7" touchscreen.
So hopefully:
Mass Music/Video
SatNav
OBDII
Digital Radio
etc
This sort of thing is nice:
http://www.stevieg.org/carpc/
Old Apr 15, 2011 | 11:47 AM
RichieST's Avatar
RichieST
Don't forget the standard hole isn't double din, it's 1.5 din. You can fit a double din unit in, but you will need to chop out bits of the inside of the dash board.
Old Apr 15, 2011 | 01:24 PM
jelly-monster
o, balls >_>
I will have to look into that.
Nov 1, 2015 06:53 PM
S3an
Sep 26, 2015 11:39 PM
coscor86
Sep 20, 2015 01:21 PM
S3an
13
Sep 13, 2015 10:01 AM
