Cosworth Management
Ask me a question!
A New Bread Of Fast Road & Race Applications
Supplied in our conversion: -
ECU, loom, pectel board, modified distributor, phase sensor components, crank sensor & bracket, injectors, 3 bar map sensor, ignition amp, water/charge temp sensors, mk 5/6 fuel filter, modified throttle body, altenator & bracket, adjustable throttle cable, modified EFI inlet manifold, fuel rail, fuel regulator, cosworth distributor cap*, cosworth distributor leads*, magneti marelli coils*, OddKidd Creations 270BHP base chip.
Our conversion is precisely engineered to fine tolerances, producing completely reliable and unbelievalbe results, all finished with the finesse it deserves!!!
www.oddkiddcreations.co.uk
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
